Looking to add a Plex server to my home.
I don't really have any spare parts laying around and want to use my current PC (maybe upgrade if needed) to be my main PC as well as the Plex server.
My question really is - Can i set CPU priority on Plex? I use Ubuntu.
The only game I play on PC is CSGO and that is relatively low core count. So I was wondering if I could maybe limit Plex to just a few cores?
Plex doesn't require much in the way of CPU resources, it can comfortably run on a Pi3 unless you use unsuitable media and serve it to unsuitable/poorly connected clients. You can also use hardware transcoding if you are a PlexPass subscriber and have suitable hardware. In Ubuntu you'd historically use taskset or schedtool.
Automation is much more efficient than doing things manually, when you get your head round SONARR/RADARR/LIDARR, Ombi and Tatulli, combine them with SAB/NZBGet and Deluge/rTorrent with VPN built into the docker and when you get fed up of doing it all on your home connection with local storage you can move to a VPS/Cloud solution with unlimited storage and massively faster connectivity. If you do it right your only need to interact with your server should be to add anything to the monitor list that isn't automatically imported from the sources you set it to pull lists from.
. Just hoping to recoup some of the cost by offloading these on ebay. The storage space i've bought covers and adds to whats in those two combined.
