- 5 Feb 2009
I bought a 980Ti from the MM here in February 2017, and was using it quite happily until I took it out of my system and sold it a couple of weeks ago.
The buyer contacted me to say the card was broken, causing PC restarts and showing screen corruption. I got it back, tested it in my PC and sure enough, it's karked it.
On reinstalling it, it booted into Windows fine, but after a couple of minutes (I assume when it tried to find and activate drivers) the screen went black with broken vertical blue lines running down it and the PC restarted. I then couldn't get back into Windows and got caught in a boot loop. On putting my 1080Ti back in there I got the BIOS recovery screen, exited and then the PC then booted as normal.
This is the same behaviour from the 980Ti that the buyer reported happening in two PCs, so there's definitely something wrong with the card itself.
I've never had this happen with a card before and I'm a bit embarrassed to have posted someone a card that doesn't work, especially over Christmas. I'd appreciate any advice from anyone with more experience with graphics card faults on this.
What could have caused it? There are no signs of damage or mishandling, there's plenty of packing foam in the box and I shipped it with the card's original box well-wrapped in bubble wrap.
Things to note:
1. I put it on my bare desk to take photos prior to listing on the MM - it's fairly clean but I guess there's some possibility of particulate contamination?
2. I notice when I opened it up again that I put it in a conductive grid bag rather than the more usual silver type of anti-static bag it came in. I can't remember where this bag came from - I must have grabbed the wrong one from my collection of component bags. Does this type of bag potentially transmit ESD from hands to the bag contents? Could this explain it?
3. When I got my UW monitor I overclocked the card a bit. Nothing too aggressive, and using Afterburner which I assume is perfectly safe(?). I took it slowly in increasing the core and mem clocks. I did get a few driver crashes before I found a clock that worked, but I played through the whole of Rise of the Tomb Raider on these settings with no crashes, and temps topping out in the high 60s celsius with a custom fan curve, so I would have thought that was all okay?
And, perhaps most importantly - anything I might try to get it working again? I recall there's an "oven trick" with dead graphics cards, but I don't know what kinds of faults this can potentially cure.
Things to note:
