Ok thank you for the info I figured my CPU would be up to the task at hand considering the power it has but I wondered about the RAM and Mo-Bo Here Is my User Benchmark With no overclocking
https://www.userbenchmark.com/UserRun/13514969
And here is the very best I could get out of it.
https://www.userbenchmark.com/UserRun/13161897
Technically this is the best overall
https://www.userbenchmark.com/UserRun/13160788
https://www.furaffinity.net/view/29965088/ P.S. its all SFW
Would like to find a game that perfectly soaks up all the cores and put them to useful work in a game. GTA5 really isnt bad engine for multi core, might be a couple more. Arma is awful, havent tried the latest Dayz version of that engine so i hope they moved it on as a giant landscape surely should like cores
Bit of a noob question. I know 0.05% of what you guys do!
Just ordered a Sapphire Vega 64 for my rig (bottom of the post).
My question - videos seem to show there being 3 x 8pin power connectors. Do you use all three (separate cables to the PSU) or just two?
....and yes I will overclock my CPU with this card
- Asus Z170-A Intel Z170 (Socket 1151) DDR4 ATX Motherboard
- Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor - Retail - STOCK. Corsair closed loop watercooler.
-Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Black (CMK16GX4M2B32
-Samsung PM961 Polaris 128GB M.2-2880 PCI-e 3.0 x 4 NVMe Solid State Drive
- Sapphire AMD RX480 Nitro+ 8 GB GDDR5 Memory Polaris FinFET DX 12 Vulkan FreeSync PCI-Express Graphics Card
- EVGA SuperNova G2 750W '80 Plus Gold' Modular Power Supply
- Philips BDM4065UC 40" 4K
It's only the limited edition that used 3 x 8pin power connectors, if you bought the card from overclockers it's the normal edition which has 2 x 8 pin power connectors and I would use a separate cable for each plug.
I'm wondering if someone could clarify something for me.
The HBM voltage in Wattman isn't actually anything to do with the HBM, rather it's the lower voltage limit for the core? and that the HBM voltage can't actually be changed (it's set in the cards BIOS)?
@DoneADougalOnSofa I received an email from Overclockers regarding the free games, check your email.
I'm looking to swap my AIB Vega 64 for a reference so itlli fit in my ITX case (thread in the wanted section on MM if anyone's interested).
Just wondering what noise levels on the reference are like at idle or watching movies/YouTube?
