I've learned this lesson with GPUs a long time ago, now I apply it to other electronics as well (TVs, Phones, etc). Mid-range more often > high-end less often. There's definitely an (albeit subjective) price/performance curve and for some products the two variables perfectly align, e.g. this year I'd say for TVs that has generally been the XF90 (though if I look at the UK the LG 55B8 could be another).
The one possible exception would be speakers, I think.
That's archaic in TV terms. Things have moved on a lot, but if your happy with it![]()
But it all depends on what suits, I had to comprise on 'only'a a 60 (which is too small) as we sit approx 15 foot away. We have since rejigged tthe room and I reckon a 75 will fit (but getting it past the Mrs won't be easy) I tend to go for mid to high range every few years, the TV is ju6800 (trust me 60" is far more of a nichenichearket that either a 55 or a 65), and I bought a gtx 1080 (bit the top but should last pretty well).i don't want a 75 inch tv though. it would look ridiculous in my home. unless i converted the garage and stuck it in a dedicated room.
so he's bought a 75 inch because he's in a 5 bedroom house. i'm in a 3 bedroom so i have a 55 inch. they will both give the same viewing experience as i will be sitting closer. so it's not apples and oranges at all.
he could have bought 3 x 55 inches. my point is buying the best every year is a stupid way to do things. you spend £3500 on a tv then a year later you are left disappointed because a new killer improvement has been made and your tv doesn't have it.
i know someone who spent £3500 on the first pioneer plasmas it wasn't even HD. they launched a year later. he kept that tv until it died like 15 years later. he missed out on HD plasmas, etc. had he spent less like £1K he could have easily upgraded to a full HD panny plasma a few years later for around £1K. he would still have £1.5K in his pocket and a newer and better tv. but he persevered with a non hd pioneer for 15 years saying it was the best tv he had ever seen. until i showed him my panny plasma. that was when he decided to get a HD LCD for a different room but he kept the pioneer until it died.
buying top end in the TV market is like buying a top end GPU every year. only for those with money to literally throw away. it's not a sensible way to do things. or it's for those that don't understand how tv's advance very quickly.
best to buy value and buy more often. value doesn't mean cheap crap. it just means bang for buck. 55" FALD with amazing HDR and blacks can be had for £1K. a tv which should easily do the next 3-5 years for most folk.
then when the next big thing launches you can get that in 3-5 years time.
the 3 tv's to buy this gen are
NU8000 - if on a very tight budget
XF90 - for gaming and pc usage
LG Oled - for varied usage
no other mid to high end tv makes sense in the value for money category
(dont think I can justify the extra for the Q9)
Hi,
Im buying a 65" TV very soon, do you think the XF90 is a genuinely better buy for PC gaming than the Q7FN (with Freesync) ?
Im torn betweent the 2 at the moment(dont think I can justify the extra for the Q9)
Cheers !![]()
This "Sony Lineup 2019" thread on AVforums maybe of interest to youThanks for the reply, think my mind is made up now.
I currently have a 42" Bravia and was fancying a change with the size upgrade - gonna stick with Sony.
Thanks again![]()
It's a token gesture though, and as I had told Sonny, has a limited number of zones ... I don't see the justification of the £200 premium over the less-zoned Panasonic,The biggest advantage of the XF90 is that it has Full Array Local Dimming
but - yes, its an individual choice based on everyones varying viewing requirements, and experience with that brand.
Slumming it with OLED and just 8,294,400 zones![]()
poor Vincent has a fatwa.just watched this new vincent video ... that reconfirms my panasonic preference ... he looks pretty stressed out compared to usual style .. you'll see why.
LG 2018 OLED TV (B8, C8, E8) Near-Black "Flashing" Problem Analysed
