OcUK Staff
Hi guys,
Moving forward FreeSync monitors will work with G-Sync enabled Gfx cards.
G-Sync and FreeSync are respectively Nvidia and AMD technologies. They allow the monitor refresh rate to adapt to the rate the frames are being pushed out by the gfx card. This reduces some of the unwanted effects that a mismatch creates, such as tearing. It allows monitors and graphics cards to work more closely together to allow the best graphical representation of what the game designers want you to see.
Until now they were incompatible but from now on all FreeSync monitors work with G-Sync, but how well varies...
For now Nvidia has tested 400 monitors but only certified 12. The ones we currently list can be found HERE
Non-certified monitors won't work with G-Sync by default, it will need to be enabled separately, and users may see issues with these monitors which mean their experience isn't 100%. My advice would be to search for more information on our forums and the internet to see what peoples experiences are in the real world with their combination of hardware for more information.
For now, to be guaranteed a flawless G-Sync experience stick with the certified monitors. I've ordered more stock so people can take advantage of the new features. Whether or not this news increases costs of Freesync monitors, or decreases the cost of G-Sync monitors I'm not sure but watch this space, 2019 is going to be an exciting one for Monitors!
Some of the G-Sync Certified ASUS Freesync Monitors:
Asus VG258Q 25" 1920x1080 144Hz FreeSync Gaming Monitor - DP, DVI @ £289.99 inc VAT
FreeSync, G-Sync Certified, LED Backlit, 1920x1080 Resolution, 100.000.000:1 Contrast Ratio, 400 cd/m² Brightness, Response time 1 ms, 144Hz, 1 x DP, 1 x DVI, 2 Year Warranty
Only £289.99 inc VAT.
ORDER NOW
Asus VG278Q 27" 1920x1080 TN FREESYNC 144Hz Gaming Widescreen LED Monitor @ £299.99 inc VAT
FreeSync, G-Sync Certified, LED Backlit, 1920x1080 Resolution, 1.000.000.000:1 Contrast Ratio, 350cd/m² Brightness, 1ms Response Time, 1x DVI-D Input, 1x HDMI Input, 1x DP Input, 3 Year On-Site Warranty
Only £299.99 inc VAT.
ORDER NOW
Asus XG248Q ROG Strix 24" 1920x1080 FreeSync 240Hz Gaming Widescreen LED Monitor - DP, HDMI @ £439.99 inc VAT
FreeSync, G-Sync Compatible, LED Backlit, 1920x1080 Resolution, 240Hz Refresh rate, Brightness 400 cd/m2, 1ms Response Time, 1 x DisplayPort, 2 x HDMI
Only £439.99 inc VAT.
ORDER NOW
Asus MG278Q ROG Dominator 27" 2560x1440 TN FREESYNC 144Hz Gaming Widescreen LED Slim Bezel Monitor @ £429.95 inc VAT
Freesync, G-Sync Certified, LED Backlit, 2560x1440 Resolution, 100000000:1 Contrast Ratio, 350cd/m² Brightness, 1ms Response Time, 1x DP, 1x DVI-D, 2x HDMI, Height Adjust, 3yr On-Site Warranty.
Only £429.95 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
