- 30 Aug 2018
Under what load?Hey all my 9900k under push pull h115i pro reaches 95c :/ 1.34v 5ghz is this normal ??so much for soldier Tim
Edit :
https://wccftech.com/review/intel-core-i9-9900k-8-core-cpu-z390-aorus-master-review/
This site uses the same cooler and at 1.352v on an open test bench (presumably since no case is listed) they are seeing similar temps.
They appear to have a better sample than you since theirs is clocked at 5.3GHz but so long as you are talking about your temps under stress testing and not minesweeper then they don't look terrible.
However, they may be a little high depending on your setup.
If you have plenty of airflow in the case and the rad is getting fresh cool air then perhaps check the cooler mount to see if it is making full contact all across the IHS.
I have tried several 9900ks where the IHS made it hard to get good even contact with the heatsink. I have also seen others showing off their IHS where the thermal paste wasn't being spread evenly by the pressure of the heatsink, indicating poor or uneven pressure.
Edit 2
I've checked a few other sources of temperature info and yours does seem to be right where it should be for prime fft with 5GHz and 1.3v going into the cpu. I wouldn't expect 90 degrees outside of heavy stress testing mind you.
