PowerColor and Sapphire any good ??
29 Dec 2012
just wondering if PowerColor and Sapphire any good ??
I've never had one of these brand before but they seam to be the cheapest available but in the past I use to hear support and warranty was not very good is that still the case ?
OP
29 Dec 2012
Id say they were the 2 best brands, ive always bought the Sapphires, and never had a prob, and those PowerColor cards (especially the Devils), are really good as well by all accounts.
Thanks are the warranty and support also as good, just in case ?
26 May 2014
They both benefit from/are cursed with being AMD-exclusive partners, so tend to put a little more work in than the likes of Asus/Gigabyte/MSI do with their AMD cards.
Sapphire in particular have tamed some incredibly hot and power-hungry GPUs better than anybody else. The 290X Vapor-X is one of my all-time favourite cards.
OP
29 Dec 2012
Thanks I was a little worried about the warranty faults and issues from the past so wanted to know.
