Shadow of the Tomb Raider Bench Thread
15 Oct 2018
How does order get decided in the event of ties in average frame rate?
I note this looks in the wrong order to me (apologies for the poor formatting, partially quoting your benchmark result lists is harder than it looks) :p
1 GPU 3440x1440
  1. Score 31, Min 24, GPU Vega64 @1687/1045, CPU 2700X @4.25, nashathedog Link, DX12, Driver 18.9.3
  2. Score 31, Min 27, GPU 1070 Ti @2000/2249, CPU 2700 @4.1, Vexr Link, DX12, Driver 417.35
There's another result like this at 2560x1440, where minimum frame rate hasn't been factored in as a tie breaker.
Not that I'm bothered :D
Man of Honour
OP
21 May 2012
Dalek flagship
It is done on Frames rendered.:)
RSR
RSR
17 Aug 2006
ill double check it tomorrow, I though I did check it all but it’s a bit late so I could be half asleep. :D
15 Oct 2018
Crikey, that's tight in the example I showed then (4961 vs 4974).
Probably could beat it, as I arbitrarily selected the memory overclock on my card for exactly between the 1070 and 1080 speeds (as I felt the 1070 Ti deserved), and used the new OC scanner thing in MSI afterburner to select my core overclock, so probably plenty left in the tank on both fronts. I think I'll let it slide mind you :p
Good to know there's a method explaining the ordering. Must be more of a PITA going down to that level for yourself though, as it's not even a detail you record in the results listings.
Anyhow, cheers for the good work.
Permabanned
12 Sep 2013
Knowhere
1 GPU 3440x1440
Sounds fair to me.
:D
15 Oct 2018
Back as promised :p
DX12
GTX 1070 Ti 2076 core / 2339 memory
Ryzen 7 2700 @ stock 4.1 GHz
417.35 Drivers
1920x1080:
2560x1440:
3440x1440:
