New driver, so cheap insurance.Is your son Benjamin Button? Or are you actually 90 years old and he's 71?
disagree ... I had the original bm stuff and moved to einzett ... complete thread just a while back...
.. silicone is the devils work
edit: maybe sonax have multiple versions
https://www.autogeek.net/wurth-rubber-care.html
edit2... utube turned up zilch .. don't take this noob's advice
Caring for Rubber Trim: Gummi Pflege vs Silicone Remover
Depends, I used to use snow foam an awful lot (and some people like the foamy nature of it blanketing cars for Insta etc...) but since trying Auto Foam and TFRs I've found my lance just sits there unused. Auto Foam itself arguably works better through the pump sprayer like the one you linked, and TFRs definitely do too. Auto Foam tends to work better through the sprayer as it has a very specific concentration at which its formulation works well. Deviating from that concentrate (4%) often results in much poorer performance.
RE sprayers, the cheap 2L hand ones also work very well and should provide plenty solution to get round the car. Something like this. If you do go for the larger ones such as you linked be sure to get a good quality one that is chemically resistant or you'll find that having left-over solution in there starts to damage the seals.
On the topic of TFR v snow foam, I've found TFR to be much more effective at shifting dirt. At the correct dilution ratios I also don't think it has a significantly greater impact on your LSP.
Some just simply dont work, ive tried probably 30+ different foams.
Imho the only ones that shift a significant amount of dirt and dwell for a decent time are:
Autobrite magifoam
Sams active snow foam
Auto finesse avalanche
In that order.
I know people love bilt hamber auto foam, but frankly its more of a TFR with bubbles than a snow foam imho.
best bit of kit I boughtBought an Autobrite Snow Foam Lance which arrived yesterday, cars currently filthy so looking forward to the weekend trying it out![]()
I find the BH foam cleans will, good for this time of year where I just down and jetwash off.
Good result for touchless, no need to go crazy perfecting it in this weather.
Did you use a whole bottle of foam to get it that thick?
I can't leave it on my car long enough to actually do anything as the sun dries it up in less than 5 mins. Is that the magifoam?
Looks like you can't get it over here![]()
Doesn't look like it is.Sams active snow foam is your next bet if you can get that?
