Anybody know why you can't buy rechargeable Lithium Ion AA batteries?
Man of Honour
29 Mar 2003
Stoke on Trent
or are my Google skills rubbish?
Now be careful, you may think you have found some until you read the descriptions and they end up being either 18650s or Ni-Mh or just a charger.
Probably due to the voltage difference between AAs and 18650s
Is there a specific reason you need LiOn rather than NiMH?
You can they're called 14500 batteries, but they're 3.7v instead of 1.5v so no using them in place of regular batteries.
Lithium Ion 14500 is AA size but wrong voltage 3.7v vs 1.5v and not a good idea to use them as unless the device is designed to use them, some flashlights for example can use those 14500 but has to be designed for them otherwise you are likely to destroy whatever you have put them in.
The protected versions of those batteries can also be a little longer than a normal AA so you might have problems with fitment and you dont want to be messing around with unprotected lithium ions if you don't know what you are doing.
Also i think the reason you don't see them in normal stores is people would be trying to charge them in a normal Ni-Mh chargers so they are specialist batteries, but you can get chargers now that do both lithium ion and Ni-Mh batteries so if you got one of those and some protected 14500's you could use them but don't put them in things that are not designed for them due to the voltage difference if you were to use 2x 14500 in a 2x AA device your now powering it at 7.4v rather than 3v and follow the usual rules of messing around with 18650 lithium ions.
I use a protected 14500 in a 1xAA nose trimmer which now runs about 3x faster and will probably burn out eventually but not the end of the world for something cheap.
I know there are examples above but they have to plug into a USB port and the Kentli are very expensive.
I guess they're expensive because it's not just a battery. It'll have a normal 3.6volt lithium cell inside and some circuit to reduce the output to the required 1.2volts and also manage the input voltage when charging. They also have a much smaller capacity than normal NiMH rechargeable AAs - I don't see any benefit to LiOn?
Thanks
I did buy a charger and some AA & AAA Ni-Mh last week but just wondered why they weren't available in Li-Ion form.
I have my answer.
The other week I bought 3x 9v Li-Ion with a charger and they are excellent.
what do you use them for - PP9 form factor ?
I wonder about getting a better quality intelligent charger to get more capacity/life out of the nimh's (conditioning) ?
it still seems that latest eneloops will have best number of re-charge cycles versus Ikea, or vapextech.
Evidently, even with the increased energy-density of li-ion, they cannot pack the additional protection elecronics into the AA/AAA batteries and keep up with the capacity of the ni-mh equaivalent.
