Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Is there a huge difference between a £20 cam and say a £199 cam, I need a cam for some footage but otherwise don't generally need one, I need around an hours of footage, the better quality the better ideally, but I don't want to spend much on it, so how would you rate a £20 cam?
An iPhone would probably better?
Angle of view, resolution, GPS, loop, wifi, vibration, motion detect, low light (seeing in the dark).
Mine have an SD card in, enough for 4 hours of footage before it loops round, it records in 2 min files. If i have an accident then I don't need 3 hours of driving and slice up the footage, i just grab that 2 min.
