Not sure which your print settings are (as in comparable names for the same parameter) but I usually do wood at 40mm/s print speed (I think retraction is the same), 120mm/s travel speed but mine is a slower printer - I've not had good results with wood stuff printing at higher speeds. (That would probably seriously add to your print times).
Atleast with the stuff I use temperature makes no odds to stuff like that other than it looks poor and doesn't print well (very rough) if I drop too low.
