Starting to get the annual coffee stains creep in, so I'll have to go for a clean I suppose. 34 and no fillings/dental work ftw.
@jpod hope you dont mind the tag but as youre a dentist I have a question for you. Ive just been to my dentist to have moulds done for whitening. He has given me the Philips Zoom DayWhite 6% Hydrogen Peroxide kit.
His instructions were to apply the gel and wear overnight for up to 8 hrs max.
Now, the instructions in the kit itself appear generic for all the different strengths, however there is a small table which says that for DayWhite 6% the wear time should be 60-90 minutes.
Oddly though, the same table in the booklet has the NiteWhite 10% and the 16% strengths at longer, overnight and 4-6 hours respectively.
So do I follow my dentists instructions or the booklet? It seems odd that the lower strength solution is the shorter wear time.
And why hasnt he given me the stronger solution? I wasnt offered any choice in this.
I hope this isnt locked/ question removed. Its only whitening gel so no serious consequences here, just hoping for jpods opinion on it as my dentist might be spouting nonsense.
Ta.
every 3 months. average cost is like £5-£12 per visit.
chiropractor is every 1-2 weeks and is £15 per visit for similar amount of time.
so i stopped going to chiro but and self adjust but i feel like i need to go for a proper adjustment once every 6 months i just need to find a decent one. i think my old one was just average.
I suspect you don't really need to find one at all.
https://www.theguardian.com/commentisfree/2008/apr/19/controversiesinscience-health
A good Physio might well be a bit more useful!
you might want to watch some youtube videos then of people who have had all sorts of issues for life getting treatment done and remarkable improvement after seeing a decent chiro in 1 session.
I'm not sure that "some youtube videos" really counter the argument put forwards by the likes of Simon Singh.
I'm sure I could find some youtube videos from people who are adamant that the psychic they went to see helped them connect with dead relatives or that the homeopathy treatment they took really worked.
Anyway, it this probably isn't the thread for discussing it, to each his own...
what are you smoking?
the youtube video shows the person has a severe issue. and it is then corrected with chiro work.
I'm not smoking anything thanks, but this is a dentistry thread not a Chiro thread. Honestly I'd strongly suggest you try a bit of critical thinking re: this rather than mindlessly believing in nonsense because you've watched a youtube video.
I am a dentist, private practice. Mainly treat adults. Most of you lot need to go for a check up once per year and the hygienist/therapist about once or twice a year. If you are susceptible to gum disease or you are eating retro sweets coding all day 3 or 4 times a year.
Decent hygienists/therapists will advise you on the recall period.
You must have a check up once a year because it is an oral cancer screen.
For those folk who have not been for years - get cracking and get back to see a dentist regularly - not all dental problems are painful - so get in there.
Even if you go to the therapist 4 times a year - you do 98% of the tooth cleaning at home - so make sure you are good at it and take the things you use to the dental hygiene visits so they therapist can coach you - make you into a black belt tooth cleaner.
x pod
