- 18 May 2010
Can someone please clarify this for me it's driving me nuts
I'm looking at a 2600X, I'm not manually OCing, I'm thinking pairing it with an MSI Tomahawk or Pro Carbon but read that PBO doesn't work too well on these boards.
Have I got the following right
PB2 is a default feature for all core boost so a 2600X will all core boost to 4.0ghz with default settings, no messing around it's just standard
PBO is an additional feature that needs to be enabled that pushes the ranges of PB2 even further over and above 4.0ghz in the case of the example of a 2600X
So basically I wouldn't care for PBO because it's a form of OCing?
I also read that PBO was 2nd gen Threadripper only but there's loads of talk about it working on X series Ryzen 2 CPU too
If anyone who understands this better than me be could clarify I would appreciate it
Thanks
Thanks
