is it still Rumored to be around 6-£700?
I believe it's going to be very good.
Tweaktown is apparently very impressed with the benchmark results but they will only release that on the 7th.
https://www.tweaktown.com/articles/...nboxed-worlds-first-7nm-gaming-gpu/index.html
100% Legit.
/Maybe.
My prediction: The cheapest card will be £699, the others between £749-£799 and the Asus one at £1099.
Nice!!!Gamedebate's results at 4K show 12 titles with similar framerate, 2 titles where 2080 leads and 7 titles where the Vega 2 16GB tops.
https://www.game-debate.com/gpu/index.php?gid=4092&gid2=4022&compare=AMD Radeon VII 16GB-vs-Nvidia GeForce RTX 2080
Look like the rtx 1080 just edges it in game debate review, so not bad for VII how well it overclocks will have to see
Change to 4K from 1080 and you'll see a big jump.
I would really really hope no one is buying these cards for 1080p.
1440p at 144Hz min or 4K should be a good fit.
The Radeon VII 16GB has not been released yet, so any comparisons on this page are likely to be unreliable.
100% Legit.
/Maybe.
Yep, I am 144Hz 1440p freesync panel with a 1080Ti (I bought the card after the monitor).
It's not clear from your post whether or not you're aware that your 1080ti should now work with freesync.
It’s ok nv deciding that they will support free sync, what about g sync are amd going to support that so green owners can switch to red?
100% not legit
So not going to be less than about £799 on the store?My plan is to inflate online webshop price to put customer off, then a voucher code posted forum only that gives like £100 off, but we are seeing if we can implement in time as voucher codes take a long time to do and our IT Director is on holiday.
