Nice! It's normally a straightforward install:
Nice and simple! The static IPs take a while to filter through unlike the Dynamic ones though due to the GRE tunnel but the engineer won't leave until its on. One thing is that you "may" not get full speed out of the install straight away - the initial speedtest only gave 20-30mbps but gradually increases to the maximum over 30-60 minutes.
- Hook up the Hitron to the COAX cable that's already there;
- Confirm the line stats and fit any attenuators/boosters needed (if the engineer has them, see note below!)
- Engineer (won't be the normal VM guys as they're "apparently" not trained for VM business installs) will phone the business activation line;
- Upto 60 minutes for the activation to be successful (the engineer will stay there until it's online);
- Two or 3 speedtests (through good old Speedtest.net) and the results will then be phoned back to the activation line as a reference;
- Clean up
Note: May be worth getting some of the attenuators from ebay as VM don't hand them out to their engineers anymore - any that are used now were already with the engineer or "taken" from other client installsBit cheeky to be honest. If not, they'll install another piece of kit (not sure of it's name as engineer didn't need one) that will take some of the upstream bandwidth to put onto the down speed. Surprised them by having a full collection of all the attenuators
Awesome. Thank you for the info. I'm quite looking forward to it although I'm going to need to tidy up my office before the engineer arrives as it looks like a bomb has hit it
.I've already got the SIM card which is working nicely. I hope the Hitron router is a good one. I couldn't find much information on it. It must be better than the Super Hub 3 though. Hopefully, it'll let me set my own DNS servers.
You'll either have to:
It is for new customers only, if your interested let me know.
