The Radeon VII Owners Thread
28 Feb 2013
Worksop
Someone did say they finish on the 9th though, not sure if that's right?
According to the website:
"Campaign period begins November 15, 2018 and ends April 6, 2019 or when supply of Coupon Codes is exhausted, whichever occurs first. "
"Following purchase, Coupon Code must be redeemed by May 6, 2019, after which coupon is void."
https://www.amd.com/en/gaming/raise-the-game
5 Aug 2017
Cornwall
Check the and reward site, the codes usually show up there before an email goes out. It's some pop-up window you get so it can redeem the steam code.
On the rewards site you open a browser window and sign into your steam account via that. It then adds it to your steam library. You don't use a steam code like normal.
Just found the instructions in my email.
This email contains instructions to activate Resident Evil™ 2 for your AMD powered system.
  1. Enter your Steam username and password on the Steam account page. If you have not already set up an account or downloaded the app, you may do so at http://store.steampowered.com/
  2. In the MY REWARDS page on AMDRewards.com, click on the “REDEEM ON STEAM WITH YOUR ACCOUNT”.
  3. In the Steam POP UP WINDOW, enter in your username and password.
  4. Once finished, click on “ACTIVATE ON STEAM”, and the game will be added to your Steam Library.
  5. Enjoy."
11 Feb 2019
Here's my photo to join the Roll of Honour! :D
As for the flickering issue I mentioned earlier - yeah, it seems that with a different web browser (Edge) I don't get the flickering at all. As a side note, I now know that Imgur on Firefox causes my screen to flicker on my AGON monitor, which is a shame.
It's just really odd, I was on a GTX980 previously and didn't experience this sort of issue at all. O.O
11 Feb 2019
uPd9ZMS
9NOrjdI
Man of Honour
OP
21 May 2012
Dalek flagship
I dont have a pen in my house this is the best i can do lol
Welcome and on TROH.:)
The Roll of Honour.
Date 11/02/2019, Make AMD Reference, Harry Hodgson, Link
Date 11/02/2019, Make AMD Reference, Otellino, Link
Date 11/02/2019, Make AMD Reference, Colzy, Link
Date 09/02/2019, Make AMD Reference, artur_k, Link
Date 09/02/2019, Make AMD Reference, Dicehunter, Link
Date 09/02/2019, Make AMD Reference, Illuminist, Link
Date 09/02/2019, Make AMD Reference, vapor matt, Link
Date 08/02/2019, Make AMD Reference, spook2575, Link
Date 08/02/2019, Make AMD Reference, L-Digital82, Link
Date 08/02/2019, Make AMD Reference, Uzu, Link
Date 08/02/2019, Make AMD Reference, drskiba, Link
Date 08/02/2019, Make AMD Reference, nashathedog, Link
Date 08/02/2019, Make AMD Reference, Chud_Jenny, Link
Date 08/02/2019, Make AMD Reference, Bloot, Link
Date 08/02/2019, Make AMD Reference, Vince, Link
Date 08/02/2019, Make AMD Reference, zoffster1, Link
Date 08/02/2019, Make AMD Reference, FordneyMcCumber, Link
Date 08/02/2019, Make AMD Reference, Vish Petrol, Link
Date 08/02/2019, Make AMD Reference, Dave2150, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Radeon VII.
23 May 2016
Lurking over a keyboard
Just saw this and wondered if this could be causing issues? https://www.techpowerup.com/252476/amd-radeon-vii-has-no-uefi-support
Not that much of a biggie IMO and easy fix.
By default motherboards have CSM enabled, as then even if you have non UEFI compliant HW you'll have POST. Once you're in OS it won't cause issues if you had VBIOS without UEFI/GOP module in.
Only those that set their motherboard for "full UEFI mode" (ie CSM disabled) will have POST issue. Then usually mobo will fall back to enable CSM, you'll get a message on screen after re-POST stating as there was non compliance, it set most compatible settings.
Raz
Raz
18 Sep 2003
Nowhere
Is there much difference between the models other than the price? I think the Vega 64 from Sapphire was the one to go for previously and it seems the cheapest of the bunch for the VII.
Also, what's a good PSU for this card? I've got a seasonic focus plus 550w gold PSU but I imagine that wouldn't be enough.
22 Mar 2015
Kent, UK; Brooklyn, NYC, NY
They are all the same: shipped from AMD to AIBs (who then may slap a bramded sticker on the shroud). Wouldn't think there's any binning going on between them. I would go for brand with which you have best CS experience amd best price (for me, that's Powercolor who gets my business since they replaced two failing 5870s with a 6990 without hassle a while back).
5 Aug 2017
Cornwall
Use this to see what your hardware uses wattage wise, its not been updated for Radeon VII yet so just use a Vega 64 to give you an idea.
https://seasonic.com/wattage-calculator#
A PSU @ 50% load gives best efficiency in most cases.
Permabanned
12 Sep 2013
Knowhere
No, A 550 watt psu isn't enough and I'd say don't risk it, On the box it states that the VII requires a 650 watt psu minimum but a 750 watt psu is what's recommended.
Caporegime
12 Jul 2007
United Kingdom
For the roll of Honour @Kaapstad :)
In my system (Vega 64 Liquid sitting at the bottom of my case but just out of shot)
Had quick go at undervolting and managed to complete Timespy Extreme stock clocks with the voltage running at 0.975v, fan speed set at maximum of 50% and GPU temp didn't go over 57c. :)
Edit
1802/1000Mhz undervolted at 0.961mv appears game stable. 0.951mv crashed.
Caporegime
12 Jul 2007
United Kingdom
@Vince @Illuminist
That got me a better result in Firestrike extreme, The first result is stock, the second is with just the power limit max'd & the third is with the tweaks and auto memory overclock. I'm not sure what's going on with my cpu though?
https://www.3dmark.com/compare/fs/18241004/fs/18227926/fs/18261261
Comparison Nasha.
1802/1000Mhz @0.961mv
1652rpm (peak)
GPU Temp 57c
Junction temp 77c
Actual core clocks during the FS run were 1770-1750Mhz roughly.
23 May 2016
Comparison Nasha.
1652rpm (peak)
GPU Temp 57c
Junction temp 77c
Actualy core clocks during the FS run were 1770-1750Mhz roughly.
My V64 is not a great clocker as others I have seen.
Seems as if clock for clock no gains on VEGA20. Sorta of shame as they respun die to have more thermal sensors, etc but no other improvements.
