- 12 Feb 2019
That was a timespy stress test at default, I touched nothing, it crashed before the end and gave me a 0 failed
The temps were 92 core and 115 junction
I then tried with a 10mv undervolt and it instantly crashed on the stress test
I turned the fans to 100% just now and ran the stress test at default. It passed the test but the junction was 109.c for the majority of the run.
So In conclusion, unless I run the card at 100% fan all the time, my games will crash.
First, I have been reading this thread (and others regarding the Radeon VII) since launch and want to thank you for all your information shared, very appreciated.
Second, since I got my card yesterday I would like to give some feedback regarding your problems Illuminist.
I think your temperature is way to high, I believe 110°C ist the point where thermal throtteling occurs and I think you shouldnt pass that if possible.
Have you checked the airflow to the card in your case? How are your mainboard temperatures?
I attached my results for two 10+mins Timespy Extreme (@1080p) stress test runs with stock and undervolt + underclock settings for comparison to your results. I also added my motherboard temperatures and the 3dmark resultpage for comparison.
My card also hits 109°C TJunction in steady state at the stress test, but lowering voltage und clock it only reaches 87°C with the fan rapidly switching between 2100 rpm and 2900rpm (needs tuning so it stays quite).
Also you could try to carefully increase the mounting pressure on the backplate like descibed here under "hotspot": https://www.techpowerup.com/reviews/AMD/Radeon_VII/33.html
It should be enough to tighten slightly the two opposing screws without the sticker, so warrenty is not voided.
Also, if undervolting try to activate the manuel fan curve. I have the impression the automatic fan curve is not working correctly and the fans do not spin as much as they should, so temperature rises to high (need to confirm this though).
Another bug is that the rpm is read out falsely in WattMan from time to time in manuell mode. It stays at ~900rpm even though temperature suggests a higher spin rate as well as acoustics of the fan xD.
I have the impression my card undervolts rather good but I still need to figure things out.
Here are my results for stock settings (1801MHz@1071mv):
Here the results of 1700 Core clock @938mv:
Hope that helps.
