Personally I'm really disappointed split screen / "multitasking" is basically useless as I use my iPad 99% of the time in portrait orientation. Why on earth isn't there an option to split the screen horizontally?
Notifications are not as useful or as well presented as they are in android mostly due to the way they are grouped or how you can interact with them. Have turned off notifications for pretty much every app.
The settings for most apps not being within the apps themselves is just strange to me and causes the settings app itself to be a bit of a mess.
I'm probably going to get roasted for saying this but I honestly find the Google equivalent of the app store to be better. Granted the selection of quality apps for iOS FAR eclipses android from what I've seen so far but the method of delivery feels antiquated in comparison. In fact that's how iOS feels in general. Very smooth in operation yes but under the hood....getting a bit long in the tooth.
Which leads me onto the final gripe - no file system or support for external storage! How can something that's been pitched as a replacement for a computer lack such basic functionality?
That being said I'm generally over the moon with mine as I bought it mostly to use Procreate with the pencil. And it's truely awesome for that.
What?File systems? Talk about long in the tooth!
Any context on the white spot issue? What is it?
What?![]()
You were talking about iOS ‘getting a bit long in the tooth’ then proceeded to ask for a file system, which is even longer in the tooth than iOS is. I was pointing out the irony of your post.
Having a useful file management system is a vital part of being a professional tool. Trying to use iOS in its current state is a total pain.
You have to import all the photos into iphotos, which is pretty weak for importing as you can only see thumbnails iirc. Then you have to import them to lightroom to work on them. There's no way to directly directly move your collections back out from iOS unless it's through the cloud (either via iPhotos or Adobe's setup) or maybe via iTunes.
It's all a bit messy.
It's an iPad Pro. Apple market it at content creators and professionals but it is hampered at that role by iOS's limitations.
I don't think it's relevant what Apple want to call it, it's what people use it for that matters.
Well I have one and would love to use it in the way it is marketed. I just can't because it's too annoying.
We're not talking about a professional tool, we are talking about the iPad.
Apple Photos is an excellent service. It keeps all of your devices in sync so when you add/delete/edit photos on one device they are automatically synced to your other devices. You can also set it so that the storage space on your devices is optimised automatically which means only some of your photos will be stored locally on your device, the rest will be in the cloud with only thumbnails on your device.
Photo storage isn't done by folders in a file management system; that's the old way of categorising photos. Photo storage is now done via the photo metadata by means of events and object/people recognition.
Apple Photos only costs 79p per month for 50GB of space and no need to use Google's surveillance products.
Hmm sounds like a step in the right direction. Will give it a try
Fixed for you. Let's call a spade a spade shall we?Maybe you just haven't compromised to its glaring limitations yet?
