Apple iOS Apps not updating
16 Apr 2007
UK
Hey all,
My mum has just got a new iPad and I’ve set it up for her but she is having a weird issue that I can’t figure out...
All the apps update correctly but the native iOS apps like Pages etc. refuse to update - they just stay in the update list in the App Store, and when I press update, it whirls around and then shows the update button again.
I’ve tried doing a hard reset and that’s where my experience ends :p
Any ideas?
Thanks,
Marky
How is it connecting to the internet? If it’s cellular then there is a size limit to downloading and updating apps.
I'd say so - But I will have to confirm. The iPad was bought for her about a week ago.
Some apps wont update unless you are using the latest iOS. Update the OS then update the apps. If this does not work, delete the app and re-download it.
It should give a notification if the update doesn't support the version of iOS that is currently installed and not just attempt to update and revert to state that an update is available.
