- 19 Jan 2003
- west sussex
Just saw this on mod on Reddit - anyone here tried it?
https://www.reddit.com/r/Amd/commen...y_personal_results/?utm_source=reddit-android
I don't see how this can apply more pressure to the surface of the GPU/HBM2 from the heatsink, the sprung metal 4 way bracket on the back of the PCB is pulling the heatsink towards the GPU with screws through the PCB.
this bracket has 4 legs one for each corner, if we were to say each leg sits off the PCB 6mm when the center of the bracket is sitting flat on the back of the PCB/GPU when you tighten up the screws the bracket is applying
6mm of sprung force to the heatsink on the other side of the PCB. if we place a 1mm thick washer to back of PCB under each leg of the bracket and then tighten the screw you have 5mm of sprung force as the washer has taken away 1mm of it.
https://www.techpowerup.com/reviews/AMD/Radeon_VII/33.html
So really this is reducing pressure of the heatsink on the GPU as it doesn't have so much sprung force pulling the heatsink, perhaps the better results come from more even pressure applied after removing the screws.
or the screws have been tightened up more evenly when putting the 4 leg bracket back on.
