- 14 Oct 2007
- newcastle
I understand what your saying and yes mad max is a very bright movie, buts it’s only very bright in small portions of the screen which is why the abl doesn’t kick in as much, its only bright sustained scenes when you get the ABL but it’s very gradual and almost unnoticeable.you sent the former back ... that sounds more like a manufacturing defect , and would not be tolerable ?
Is there an explanation of why bladerunner was mastered with lower nits ?
HDR sets might just scale of the brightness within the range available on the TV, so objectively BR and meg might appear just as bright,
the meg high brightnesses are obviously not reproducible on home tv's, and will be subject to the diverse lg or panasonic eotf curves, so maybe the product would be less consistant across tv's, vs blade runner.
Blade runner is barely exceeding the sustainable hdr on an oled, so maybe they have an eye on the target tv's too.
if you have sustained high brightness across multiple scenes on an oled, I assume it will not start backing off the brightness after the scenes have lasted more than, 10s, say.
(or whenever the abl cuts in) that would be un-natural , like enabling dynamic backlight options on a led.
Yes if you were to put a Q9/ZF9 next to a OLED in a bright room without a doubt you would see how much brighter and more pop it has in HDR than the OLED, but then put that same tv in a normal lit/dark room and you you burn your eyes with the Q9/ZF9 where as the OLED will give you a better movie experience and no eye strain. Don’t get me wrong I’m not an OLED fanboy I have a 55XE9005 in my bedroom which I love and it is totaly perfect in every way, and if I could guarantee getting one as good as that uniformity wise in 65/75” I wouldn’t hesitate, I have tried 2 65Q9FNs and the DSE was horrendous on both.
