- 19 Feb 2007
- Northampton
We have more Vega cards to come first as I understand.
So lower versions of the Radeon 7 at lower prices ? Radeon 5 maybe ? Where did you read this ?
Check the date.
Isn't the 7th supposed to be some anniversary for AMD?
I'm curious if Navi will replace Radeon 7, Would be a bit odd releasing Radeon 7 and then only a few months after making it obsolete with Navi or maybe Navi is mid range i.e a Polaris replacement.
Navi has always been discussed as a midrange replacement, so that's RX580, RX590 and both RX Vegas replaced. And by extension, no, Radeon VII isn't be replaced just yet, but I think it will be by the end of the year or Q1 2020.
Based on nothing more than pixie dust and wild speculation on my part, I think the leaked RX 3080 specs are for a cut-down Navi 10 die, which means a full-fat Navi 10 die could be waiting in the wings. If cut-down Navi 10 is rumoured to be Vega 64 + 15% performance then a full-fat Navi 10 could be Vega 64 + 25% performance or higher: that's Radeon VII territory. The only thing stopping AMD from releasing it sooner is the 16GB VRAM precedent they set with Radeon VII - how to you get 16GB GDDR6 onto the PCB? Because you know if they drop down to 8GB then there will be a *********.
VII seems to me anyway, to be failed Instinct cards that were converted to GPU to sell, rather than lost the chip entirely.
then a high end Navi will replace the Radeon VII next year or even 2021.
AMD patent could bring Nvidia’s variable rate shading to Navi and next-gen consoles
https://www.pcgamesn.com/amd/amd-variable-rate-shading-patent-navi-next-gen-consoles
The use of motion adaptive shading is most obvious when applied to something like a racing game, or something like Grand Theft Auto, where there is a huge amount of motion. Things in the middle of the screen, such as the car or character, which aren’t be subject to a lot of relative motion will be rendered in full. Everything else that is moving rapidly can then be rendered at a lower rate as they don’t need the same level of detail. Our eyes can’t perceive the pixel quality difference when they’re flying past at speed anyway.
