- 8 Jan 2007
- London & Dubai
Will the following single 280mm rad be sufficient to cool a 9900K & RTX 2080Ti?
https://www.overclockers.co.uk/ek-water-blocks-ek-coolstream-ce-280-dual-radiator-wc-99h-ek.html
Plan to use these fans in pull config with it:
https://www.overclockers.co.uk/ek-w...-140s-bb-500-1150rpm-fan-140mm-fg-006-ek.html
or will this 360 serve me better?
https://www.overclockers.co.uk/ek-water-blocks-ek-coolstream-pe-360-triple-radiator-wc-488-ek.html
are there any rads I should consider?
my case is a Phanteks Evolv m-atx, gives me 75mm of space between the front mount point & GPU, ideally would like to keep the rad/fan combo down to about 70mm
