- 20 Oct 2002
- In a house
Thanks for that Kermit. I will take a look!
The bike is riding a lot more nicely now. Had a few blasts on it today after work and it feels a lot more solid.
I was only really out to get the oil warm for an oil change, but actually came back, sat down for a minute or two (Mrs and kids were out on a playdate) and got up and went out again
Oil change is now done, and there are a few more bits to clean (rear wheel, rear arch to start) but I will be taking it on a longer ride tomorrow to go play hockey and come back later on. I will be able to give it a run down some a-roads and blow out any cobwebs on the way hopefully.
I have found a slight fuel leak from the carb bowl drain screw once the bike is stopped. I tried all of my o-ring supplies, but none were a suitable replacement, so I wedged in a bit of rtv sealant around the screw head for now. I have managed to find the specific 1.3mm x 4.3mm o-ring and ordered it on from Germany for later this month.
I have also ordered a bit of carbon wrap to cover some of the black plastic panels on the middle of the bike. They are scratched up and part of the larger rear seat panel, so I didn't really want to paint them. This seems like the best option for now. I will need some HRC stickers to replace the ones that will be removed/covered to keep it looking mostly stock.
I had a go at fixing the broken indicator, but have found it to be a bit too hard to fix satisfactorily. As such I have ordered in some LED indicators. I do have some spare LED flasher relays somewhere, so should be able to make the change fairly easily.
I also decided that I was not comfortable running that chain for much longer and decided to order in the full chain and sprocket sets to give me peace of mind going forward.
Lastly, I am keen to look at the exhaust. The end can looks great and is in very clean condition, but the manifold back still looks a bit corroded and untidy. I will likely remove it and look to give it a coat of VHT exhaust paint once the garage warms up a bit.
So far it's going well and the level of work needed to bring this back to as new as possible seems less than the Chinese bike needed!
Some more pics to come after the weekend I expect!
