Vcore - 3.25v
Running Realbench Stress i usually hover around 70c and popping up to 80c every now and again.
Incredible temps for that Vcore.
You mean 1.325V?
I'll edit it!Doesn't seem too bad does it.That CPU is definitely golden.
Have you checked EIST and C1E as well. ?Having an issue with my 9900k at the moment, been running it since december..rock [email protected] @1.275v. I am noticing the clocks are underclocking to 800mhz whereas before they stayed at a constant 4.7. Intel speedshift is disabled and I'm using ultra performance windows power plan. The only thing that has changed on my system lately was a windows update last week. Bios profile is the same as its been for 3 months. Windows power plan is unchanged. Any ideas?
He was asking why his frequency was suddenly dropping to 800mhz, that's why I asked if he had checked "speedstep".No real need to disable low power states on these platforms.
Observation on stability:
I followed the Gigabyte official guide which gets me 5ghz @ 1.26v LLC Turbo (no AVX offset). That's what I've been running for some time.
Then I tried buildzoid's method of getting to 5ghz from his latest RAM overclocking video. That got me L0 Cache errors in Intel XTU which was weird.
In my particular case, the Gigabyte guide gave me more stability. The difference could be our mobo? He using the Z390 Master and mine is a Pro/Wifi.
CPU lottery as then different Mosfets being used .
believe now Gigabyte will work closely with buildzoid after he and others destroyed their z370 range and x470 Ultra situation .
Stick to the Gigabyte guide then, as you said, you had it running nicely using that guide.It wouldn't be CPU lottery as I'm talking about my CPU in both cases of testing?
I'm talking about the different in methods of achieving 5ghz through bios.
Both disabled, can't get my head round it.Have you checked EIST and C1E as well. ?
