My main setup
Schiit BiFrost -> Asgard 2 -> HD650
Looking for a nice pair of closed/semi closed headphones now for under £200. Suggestions?
Not sure if you'll get hit with customs but you can buy a similar stand on aliexpress for £28
A pair of headphones for under £200 eh,
I know this is 250 pounds but look into the meze classic 99 it has got rave reviews and if your after a headphone that delivers the emotion of the music then look into these.
They are a very fun sounding headphone and very musical apparently from what i have read regarding the reviews of the meze classic 99.
Dan.
Getting looks of the missus a lot over my AKG K7xx. Im beginning to think I need closed back headphones to keep the noise in ??
Any suggestions ? Was thinking DT880 but not sure.
Thanks
Made a new addition to my setup
I'm by no means an expert but the Atom seems more neutral compared to the Magni 3 I was using previously. Source files sound natural and balanced.
Recently did the same, Magni 3 to Atom, and I agree with what you're hearing using K7XX too. I have the OL Dac as well, as the modi 2 uber i bought before the button was faulty and would randomly change inputs, which was infuriating mid-game to have the sound cut out.
The D10 reviewed higher on ASR over the OL Dac, I wanted Optical Input though, have you heard about the Khadas Tone Board you can get them for like 60 quid (need to then also buy a case for it though) reviews better than like some £1000 dacs.
Yeah read up on the tone board, looks quite interesting. Similar to an idea I had at one point of using a Pi with a Phat Dac. Would work out a lot cheaper and still does 24-bits at 192KHz too. Not sure if I'll ever need optical or not unless phono becomes obsolete. Would you say you've noticed a difference using optical?
Do you hear a rather noticeable humming noise from the Atom's power adapter? I thought mine was faulty but apparently it's normal from what distributor said.
I have an Atom on my desk, and have spoken to 2 other customers, the buzzing and heat is a normal thing from these power supplies, and is nothing to worry about. I do understand that they are a little noisy if you are sleeping in the same room though. Feel free to check this with JDS Labs if you wish: [email protected]
Sorry to hear that! A buzzing sound indicates shipping damage to the power adapter. It should be warm to the touch, and contains a fuse for safety. That said, I recommend requesting anther 16VAC adapter from your retailer, as buzzing can be annoying.
Let me know if you need more help.
Wondering if you got it from the same distributor as they so far haven't offered to replace it:
I must say that having since raised it as a concern the noise does seem to have subsided somewhat but it is there if I put my ear next to it. Before that I could hear it when I turned my PC off and amp was still on at the wall. I'm lucky in that I sleep in a separate room to where my PC is so I'll give it a few more days and go back to seller if needed for a replacement. For what its worth, mine plugs straight into a mains socket rather than a surge protector.
Anyway main thing is how impressed I am by the amp. Think I'll make the right choice in keeping it and selling my Schiit stack.
@luggles have you had to use the gain for the K7XX? From what I know they are fairly easy to drive. My DT770 Pro's seem to perform okay without any gain too with volume set to around 11 o'clock.
