 - 11 Sep 2013
NVM
							Atm when people switch to pre-payment meters the meter is swapped out, that meter can cut u off. Normal meter can't.Have they lost the ability to do that since the 1980s, then?
Should have said "mandatory variable tarriffs" I guess. If ur meter is dumb they can't force this on you.[variable tarriffs] We already have that, too.
no, it's pence per kwh and doesn't matter what time of day you use it.There's always been peak and cheap times, no? Since the brownouts of the 1970s?
It's my understanding that with a "normal" meter, to actually cut you off, electricity suppliers need a court order to enter your property and disconnect you (amusing the meter isn't outside), whereas for a smart meter it can be done purely remotely.Ah, so the meter cannot cut you off..... but the company still can, if you don't pay your bill or something.
Neither of those articles re relevant to the new SMET2 meters which are being rolled out though which will allow cross supplier compatibility.
Plus their arguments against are basically that they don't save people money, they can only do that for people who reduce their usage based on the smart meters output. It can't just magically cut bills.
I think they're worth it for the convinience of not having to take manual readings if nothing else.
Which one do you think is more likely to happen by mistake?
Well, the citizensadvice website seems to suggest that they don't need to involve the courts when smart meters are being used.Either as they still have to goto court to obtain the go ahead to cut you off. Besides not all smart meters out there have that capability anyway.
But even if they do, energy suppliers don't exactly have the best reputation competency wise. If they have the technical ability to cut you of remotely, it seems quite plausible it's going to happen from time to time by mistake.
No they won't, once a smart meter is.installed it's staying unless it catches fire! The meter and obligations to that meter no longer belong to the supplier, once it's enabled on the smets2 network it belongs to th dcc.Most of the major suppliers will have them removed for "health reasons" if you do not want one.
Had one for ages but when I changed suppliers they can't use it so I'm back to just manual readings off it. Pointless.
You can't even sign up to some suppliers if you already have one.
