Caporegime
- 13 May 2003
- Warwickshire
Bought two large containers of adblue from Amazon and have just wacked one into my car (E Class if it affects the answer).
The instructions say keep pouring until it stops, and not to overfill, but towards the end of the container it suddenly started spewing out from somewhere underneath the vehicle?!
I wiped the drips from the filling area and off the paint using cleaner / detailing spray, however my question is - why does it matter if I overfilled it?
Seems like something did its job and started depositing the excess onto the driveway. And presumably all over the underside of the vehicle...
I turned the ignition on and it correctly registered a full tank of adblue, with no warning messages about it being overfilled.
Do I need to be concerned about anything or take any action?
