The Amd one has diss enabled.
My bet is that the AMD one is the graphically correct with the haze all over the place and the sun through it. But Ubisoft needs to confirm it.
I was blown away with the image quality of V56. Pin sharp, whereas 2060 looked pale and blurred/washed out. Tbh though i didn't mess with the video setting and just got a V64 instead and washed my hands of Nvidia. Still blown away at the render quality of this Vega card. Nvidia seem to go for a corner cutting graphics solution.
These are the conclusions I've come to from my own experience but I could be wrong. I use Display port btw. The old 780ti was on HDMI and i'm sure it used to look better than the 2060 did so maybe Nvidia don't work, stock out of the box, as well with DP? I don't know other than i loved Vega and hated RTX so went back to Vega with the sapphire nitro and i'm loving it! AMD wins in my home!
There is no perfect compression and decompression without some loss on the fly
Yes there is. ZIP is a lossless compression.
It's just that in this area, vendors choose lossy compression for less CPU and memory requirements.
You are not alone. Saying that since moved from 1080Ti to Vega 64. I rather have 120fps instead of 150 and better image quality.
Nvidia decided to compress textures the visual impact will be higher or lower. Amd uses the Nvidia equivalent of "High Quality" setting (in control panel) as standard, that reduces performance on Nvidia gpu's by 10 to 25% (mass effect Andromeda has a huge performance penalty).
As for color, contrast and vibrancy a screenshot wont show you that for obvious reasons, they are driver level calibrations displayed to the display, not created GPU side.
Nvidia likes to use this compression for two main reasons, the first is to gain FPS comparable to AMD, the second is to use less vram (up to 1.9GB's in 4k, equivalently less in 1080p).
If you don't believe me you can actually set setting in Nvidia control panel to output the same image AMD gpu's output by default.
dynamic output range: full video output range: full (0-255) Anisotropic Filtering 16x Shader Cache: On Texture Filtering - Anisotropic sample optimization : Off Texture Filtering - Negative LOD bias : Clamp Texture Filtering - Quality : Higher Quality Texture Filtering - Trilinear optimization: Off
All of these : optimizations are ironicaly visual downgrades and/or compression to increase frames.
In color settings (to have same output as AMD)
Use Nvidia settings Contrast 65% (+15% offset) Digital vibrance 55% (+5% offset)
Enjoy what every AMD owner knows as the "amd image"
some dude on reddit on this topic
if someone with nvidia gpu could test
