New PSU recommendations please.
30 Oct 2013
Need a new psu for my son's pc as his old corsair cx500m has popped.
I5 4690k (No oc)
Rx 480 gpu
3 x 1tb hdd
1 x ssd
2x8gb ram.
Corsair rgb kb and mouse.
Dvd drive.
Pc is in use like all day everyday.
Have been looking at 650w but not sure if I can go lower.
Around 80 squids if possible.
This or the antec earthwatts 650 gold pro with 7yr warranty for 80 notes?
antec earthwatts gold pro is basically a seasonic focus (non-plus)
internals are all the same, but it's semi modular, compared with fully modular for the seasonic focus plus, and antec hcg gold :)
so, basically, not worth it. extra few quid for fully modular and extra 3 years warranty is better value
Was thinking that the higher wattage will run cooler/ less strain with the intended usage??
doesn't quite work like that. peak efficiency for a psu is between 50-70% (50-80% in some psus). the difference in efficiency in this zone is literally 1-2%...ie very minimal energy losses.
load wattage (at 100% cpu and 100% gpu) is something in the region of 350w max...
550w is enough.
Thanks for the info.
I have just used the seasonic psu calculator and it states load wattage as 445w with a recommended PSU wattage of 495w.
Is there enough headroom with a 550w PSU?
How accurate are the online calculators?
here's one from anandtech: https://www.anandtech.com/show/10446/the-amd-radeon-rx-480-preview/6
I5 4690k (No oc)
Rx 480 gpu
3 x 1tb hdd
1 x ssd
2x8gb ram.
Dvd drive.
That's 350W level power draw at max.
Intel's TDPs of that time were pretty honest, and factory overclocked RX480 would be in class of 200W.
https://www.techpowerup.com/reviews/MSI/RX_480_Gaming_X/21.html
Despite of brand image that Corsair uses cheap components and was never built to last.
Would have been time to replace it year or two ago.
not very since the whole idea is to make you overbuy lol :p
it is in their interests after all.
you can do your calculation yourself:
4690k tdp 88w (https://ark.intel.com/content/www/u...-4690k-processor-6m-cache-up-to-3-90-ghz.html)
rx480 tdp 150w (https://www.techpowerup.com/gpu-specs/radeon-rx-480.c2848)
= 238w + extra 20% for overdrive/mce (at worst)
add 40w for the rest of the components
=325.6w
Ok, I appreciate the help.
I will go ahead and buy the seasonic you recommended. Thanks for your time :)
The corsair PSU has lasted around 5+ years and has been faultless - until now.
My lad uses his PC a lot, marathon gaming sessions etc and now uses it for his uni work doing game design. Probably 16 hour sessions daily.
In that kind use cheap PSU using cheap capacitor should be replaced before five years.
Those parts and PSUs simply won't survive enthusiast/heavy duty use.
Likelyhood is good that if you looked inside that dead PSU, you would find blown capacitor or two and more of them bulging.
(semiconductors often go with sharp bang and failing capacitors would be likely root cause)
Quality should be first priority and more oversizing only after that.
While 550W would be enough at least that Bitfenix Formula has only one PCI-e power cable.
So 650W PSU like that Antec Earthwatts Gold Pro or Seasonic Focus Plus Gold would be better.
For any higher performance/power consuming graphics card using separate cables for both connectors is what should be done.
It gives graphics card more stable 12V and better ground reference. (current induced voltage loss happens also on return path)
Also using one cable instead of two quadruples power losses in cable and hence heating of wires.
(power = current^2 * resistance)
