- 25 Mar 2004
- Fareham
Mine arrived too but I've not had a lot of time to play about with it.
First impressions are that it's such a large area to work in! It's going to take a big of getting used to. The screen build quality looks good, the stand is pretty substantial as well. It lights up but it's facing a wall so maybe not the most useful feature.
BLB looks manageable after I turned the brightness down a bit. I took a picture of it, but the picture looks a lot worse than it does in real life. Can't figure out how to change it so the picture matches what I see.
https://i.imgur.com/YIUeiQ0h.jpg
A bit of BLB bottom left, bottom right, top right. Top left is OK. None of them really seem noticeable in real world usage so far. Hopefully they improve a bit with time as well. I checked my Acer XB271HU before I put the AW one up, and that had surprisingly little BLB.
I seem to have a bit of a colour shift going on though, especially on a full white background like you get on the google homepage or the backdrop of a windows window. The right 1/3rd seems to give a warmer/yellowish white, where the left is more of a cool white. Does anyone else have this? I could probably get rid of a lot of this issue by getting darker skins for things!
There is a minor dent out of the top of the casing which is a bit of a shame, as the Amazon advert said it was like new and only the packaging was damaged. Otherwise the condition does seem reasonable.
Overclocked to 120HZ and it at least boots in. I am not sure if it will hold the clock during gaming, or as some people report after several weeks it can start to have flickering.
Edit - manufacture date on the box is October 2018 so at least it doesn't seem to be an ancient one that's been kicking about.
