- 30 Aug 2018
Smart Gengu.Also worth noting, played against a nano-blade and the first thing he did was kill the immortality field device before slicing up half our team.
Look like some much needed balance coming back to the game with the nerfs to reaper and mcree. shame on them really for taking so long to revert the changes.
nice to see the mei buffs thanks for pointing that out stu.
new character is level 3 difficulty so no good for me. nice to have another healer in the game.
did I read it right lucio is even faster off wall riding? should be fun!!
Yep reduced amp it up speed percentage, but increased wallride speed boost. That and the changes to boop physics might mean you are now a Lucio main now !
if that's true lucio lucio will get lots more boops than he used to.
Basically means free kill for lucio if he catch you on a bridge or near the edge.
I hope it's true.
I've been suffering from bad lag spikes recently. Ranging from my normal 34ms to 60+. It keep going up and down...
I've reset game cache, reset router etc.
Any ideas? Seems ok in quick game but in Comp it's been all over the place for the last 2 weeks.
The other change is that an opponent killed by a teammate after a boop gives you an assist elimination (didn't before, which surprised me).
Season 15 started then? Time to bang out some placement matches.
Is it only OW that you are having the issues?
Maybe test your network for normal function, thats a good start.
Run a long ping test to something to see if there are many or regular drop outs?
Wired or wireless? I started to get ping spikes. Found out my power line adapter was on it's way out. Lost 50SR due to it a while back. Only times I've ever left a game of comp![]()
Do you have any apps in the back ground game capturing? Shadowplay or the such?
Good luck doode! Let us know how you get on.I might return for season 15.....going to torb main this season I think
