So it's happening with the LQ BIOS but on the reference air Vega?![]()
Hope it's not the case because BIOS modification = unsupported config.It would appear so, we are getting closer
Why would it only now be a case with the 19.2.x drivers though? It's weirdHope it's not the case because BIOS modification = unsupported config.
No idea Tony.Why would it only now be a case with the 19.2.x drivers though? It's weird
No idea Tony.
How they can check if we flashed to LQ bios on air Vega? And I wonder if the issue would happen on real LQ Vega or not?
Interesting is that we can oc our air Vega with the default bios reaching to the same power state as LQ64 under water cooled, will the issue be existed or gone?
Cool, good luck let us know how you get on.
I'm sure you are aware, but to make sure you flash the 220w not the 200w bios.
No worries after watching your vid's I knew something wasn't right. Hopefully we can get it fixed by the driver team.Tha
Thanks for your time on this one Dave, it's helped confirm a lot.
flashed back to 1806 bios, I can also confirm the problem is gone using the 19.2.3 driver.
That's kinda good to know. How's your overclocking on this bios?
  It's maintaining 1690mhz core right across all benches and games using same lower voltages as previous bios.  That's only 10mhz down on the set frequency, where as previously on the LC 8774 bios, setting 1700mhz core would normally work out about 1650mhz average when benching and gaming.I've not messed around to much mate, just wanted to run it back on stock bios with 19.2.3 at default balanced values. Getting late now, bit tired so I'll play around in the morning to see if at least 1700/1100 Is possible using reduced power limits.
The curious in me wants to try another LC BIOS LOL
@shankly1985 EDIT update
You know what mate, I've got a very interesting video to be posting up tomorrow lol. Long story short, for you and the others. Back on the stock bios 1806, 19.2.3 driver, bug does not appear, everything is perfect again. Just back on my old gaming custom profile which is 1700/1100 frequency....the core is maintaining even higher frequency than it did on the LC 8774 BiosIt's maintaining 1690mhz core right across all benches and games using same lower voltages as previous bios. That's only 10mhz down on the set frequency, where as previously on the LC 8774 bios, setting 1700mhz core would normally work out about 1650mhz average when benching and gaming.
Might push for 1750mhz tomorrow morning then we truly right back to where we were, but it might actually end up being better in the long run. How things work out.
 Nicely done guys on finding this bug? Is it a bug with that BIOS? Anyways least you can now enjoy latest drivers.GG manNicely done guys on finding this bug? Is it a bug with that BIOS? Anyways least you can now enjoy latest drivers.
