^ Glad to see you found the solution.
No way I'd be able to convince anyone to look at fixing an issue caused by flashing a different BIOS.![]()
Not really actually, the Liquid Edition BIOS was not designed for the air reference Vega.nope probably not, you gotta admit though, it's very strange that we all had the issue with that bios on a ref card yet yours on the genuine LC64 was fine.
I'm getting incredible performance back on the stock bios though, I was not expecting that.
I've not messed around to much mate, just wanted to run it back on stock bios with 19.2.3 at default balanced values. Getting late now, bit tired so I'll play around in the morning to see if at least 1700/1100 Is possible using reduced power limits.
The curious in me wants to try another LC BIOS LOL
@shankly1985 EDIT update
You know what mate, I've got a very interesting video to be posting up tomorrow lol. Long story short, for you and the others. Back on the stock bios 1806, 19.2.3 driver, bug does not appear, everything is perfect again. Just back on my old gaming custom profile which is 1700/1100 frequency....the core is maintaining even higher frequency than it did on the LC 8774 BiosIt's maintaining 1690mhz core right across all benches and games using same lower voltages as previous bios. That's only 10mhz down on the set frequency, where as previously on the LC 8774 bios, setting 1700mhz core would normally work out about 1650mhz average when benching and gaming.
Might push for 1750mhz tomorrow morning then we truly right back to where we were, but it might actually end up being better in the long run. How things work out.
Great work Tony. I was just about to do some testing this morning. I’ll give that new firmware a go and report back.
.Who would've thought using the BIOS designed for the GPU pays benefits, hey Tony?Keep us posted, things are working amazing here now, it's actually running better on the 8706 stock bios compared to the 8774 LC bios. Maintaining higher average stable clocks when gaming, about 9c down on temps when under extreme load also.
So far this has actually worked out better in the long run believe it or not.
Who would've thought using the BIOS designed for the GPU pays benefits, hey Tony?![]()
Perfect resolution.Haha I know right. We are all tinkerers at heart Matt, putting the LC bios onto the card once in the loop was only done to really allow for stretching the cards legs at 1750hmz and up with a higher power ceiling. But seeing as those benches have been done, then I'm more than happy to run cool and fast at 1700/1100 now which can easily be done with much lower voltage as you well know.
Support For
Fixed Issues
- Devil May Cry 5
- Up to 4% average performance gains with AMD Radeon Software Adrenalin 2019 Edition 19.3.1 vs 19.2.3 on Devil May Cry 5 with Radeon RX Vega 64. RS-287
Known Issues
- Radeon WattMan settings changes may intermittently not apply on AMD Radeon VII.
- Mouse lag or system slowdown is observed for extended periods of time with two or more displays connected and one display switched off.
- ACER™ KG251Q display may experience a black screen when connected via DisplayPort™ and enabled at 240hz.
- Video playback may become green or experience corruption when dragging the Movies and TV application to an HDR enabled display.
- Rainbow Six Siege™ may experience intermittent corruption or flickering on some game textures during gameplay.
- Mouse cursors may disappear or move out of the boundary of the top of a display on AMD Ryzen Mobile Processors with Radeon Vega Graphics.
- Modifying memory clocks on Radeon VII in Radeon Wattman may intermittently result in memory clocks becoming locked at 800Mhz.
- Changes made in Radeon WattMan settings via Radeon Overlay may sometimes not save or take effect once Radeon Overlay is closed.
- Performance metrics overlay and Radeon WattMan gauges may experience inaccurate fluctuating readings on AMD Radeon VII.
- Some Mobile or Hybrid Graphics system configurations may intermittently experience green flicker when moving the mouse over YouTube™ videos in Chrome web browser.
No and it's not going to be, use the original BIOS that shipped with the GPU.Someone knows if LC bios problems on air card got fixed ?
