Cheap VPS
Status
Not open for further replies.
15 Feb 2008
Hi,
I've never used a VPS or similar before and this is only thing I can think of setting up.
I share my emby server with family (only 5 users) along with sabnzbd, they basically watch/download what they want whenever and stream from my home. (Larger files are streamed from gdrive which I upload manually via browser)
Problem is I need my upload connection at home more now so was thinking of setting up a VPS and installing sab on it and upload from the VPS to gdrive so they can stream from gdrive rather than me directly.
Are there any VPS which a quite straight forward to setup and also have access to a web browser? (I prefer to manually upload to gdrive so I can sort files myself before uploading)
Only needs 80-100GB storage as files will not be stored on there
I have very limited Linux knowledge but looking about Windows OS are quite expensive.
Cheers.
1 Oct 2006
Take a look at Digital Ocean. I got $100 of free credit recently on a new account which equated to a good few free months.
Also I used them a few years back to host web, mail and Teamspeak services and they we're very reliable.
Just make sure you whitelist IPs using their firewall service, or firewalld/iptables on the droplet.
29 Dec 2002
Ignoring my opinion of emby for a moment, Hetzner is from €3/m for an NVMe based VPS with shared 10Gb uplink, but if you have GSuite, then use the $300 free credit with GCE. As for ‘manually’ doing anything, that’s a lot of work, seriously consider automation and watch rather than doing manual imports etc.
OP
15 Feb 2008
I tried Digital Ocen and seems a 2 Vcpu is not quite powerful enough to run Sabnzbd? ... CPU seemed to be at 100% usage constant.
@Avalon
I also tried to sign up at Hetzner, provided my photo id as requested but was rejected? and now seems my ip address is blacklisted.
Not sure why as I used my home details and a full scan of my driving licence.
Any others which are capable of running Sabnzbd?
29 Dec 2002
@Avalon
Did you use a VPN? If you have GSuite and haven't used the free credit, then i'd start with that, you can fill up gdrive very, very quickly like that.
OP
15 Feb 2008
Not 100% on the VPN, I usually disable it when using bank card but may of forgot.
I'll see if I get a reply from the customer service email
Will go and check out GCE now.
OP
15 Feb 2008
thanks, have GCE setup with 4Vcpu & 4GB RAM and is running perfect.
I prefer to check everything that is downloaded for picture quality or if there are any Repacks/Propers than I will replace the originals with these, yes I know Sonarr ect can do this .. my family have only just got the hang of nzb360 :rolleyes:
On my homeserver everything runs automatically which is what I'll continue to use at home.
30 Dec 2003
i've been using linode.com for a few years and they've been great. not as comprehensive list of APIs available as Digital Ocean but does everything I need.
Status
