- 19 Feb 2007
- Northampton
4K is 3840x2160. How do you expect it to work on the 3440x1440 panel?
With black bars at the side, VSR gives the option of 5120x2160 yet I don't have a 5K Ultrawide.
Nice sig @Dicehunter
Recently sold my Titan XP and now have a RX 580 as I don't plan on doing much or any gaming for a while. What I noticed again was how much better AMD's driver UI and feature set is. Don't understand why Nvidia are lagging behind in that department.
Hi guys, have had a weird issue where amd driver crashes on Win10 shutdown when on "Computer is shutting down" blue screen (failed to initialise memory error message, haven't got a pic unfortunately as obv can't get a screenshot). Updated to the new 19.3.2 Optional version with no luck; clean-reinstalled with DDU to both 19.1.1 and then back to 19.3.2 with no luck. GPU's never been overclocked/undervolted/etc, just had a custom (more aggressive) fan profile set in Wattman - which is the whole reason of me posting this as the custom profile keeps resetting to default after each driver crashany help would be appreciated!
I'm on a Vega 64 and this is using the last two beta drivers.
On my normal UW 2560X1080 my undervolt works perfectly fine.
However, as soon as I Windows + P to go to second screen only (My 4K OLED) the voltages I've set are ignored.
Thoughts? This happens with either Wattman controlling the voltage or AB. So it's in the AMD drivers one would assume.
I mean I can literally be on the desktop and have AB sat there monitoring my voltage. It'll be at 850mv per the P state set.
I then send it to my 4K and it's sat there at 1049mv.
Set a profile up on Wattman and save it to file. When you switch to TV does Wattman reset to default? If so maybe you could load profile up again for the TV and then hopefully switching between monitor or TV will also load wattman profile? I not sure I dont use this type of setup my TV is still not connected to my PC.
It doesn't set to default.
It just sticks to something other than what I've set though. Consistently.
Ive had the same issue over the last two days. im currently using my sons Rx470, and all of a sudden the screen will go black and then turn off. I have to manually reset my pc. its been getting more frequent, ive even formatted, but I still have the same issue. The program 'Whocrashed' gives me the below error.
Its odd, because ive been using the same drivers for nearly a month and its only started to be a problem over the last two day.s
Might be worthwile trying to do a clean reinstall (i.e. with DDU)? This looks quite sever in terms of symptoms and frankly very annoying :/
Strangely enough I haven't had any issues in the last 4-5 days with driver crashes. Haven't done anything to fix it, it just stopped crashing on shutdown. Also a bit off topic, but even though we have Generation Zero-ready drivers, the game itself unfortunately looks a bit bland :|
My dad has been having constant crashes using his 590 in a brand new system, no overclock on any system parts, latest drivers on windows 10.
I’m guessing it’s a common issue?
Yeah because the error report is from Radeon.are you 100% sure its the 590 and not a system crash because of ram or anything else. can you list your dads system parts.
