PDO MySQL Query
Man of Honour
26 Dec 2003
Shropshire
I'm just looking at the SQL side as I've never worked with JSON but would this work, so the model name will be included in your count of the models statement.
Code:
SELECT `name`,`model_id`, COUNT(`asset_details`.*)
FROM `asset_details` INNER JOIN `model_name` ON `asset_details`.model_id = `model_name`.model_id
GROUP BY `model_id`,`name`
3 Jun 2005
The South
Just for clarity, here is the JS for the chart:
Code:
<script type="text/javascript">
//doughnut
  var ctxD = document.getElementById("doughnutChart").getContext('2d');
  var myLineChart = new Chart(ctxD, {
    type: 'doughnut',
    data: {
      labels: ["Car", "Bus", "Lorry"],
      datasets: [{
        data: <?php print json_encode(array_values($resultArray)); ?>,
        backgroundColor: ["#F7464A", "#46BFBD"],
        hoverBackgroundColor: ["#FF5A5E", "#5AD3D1"]
    options: {
      responsive: true
</script>
You'll note that the labels are added in manually but the data is using the php print from the resultarray. If it was possible to do a second print json_encode for the types (remembering that they are in another table and would need joining and sorting correctly), I would die a happy man! :D
The problem with this method (and current query) is that it isn't always guaranteed the total integers will be in the order of your labels - so whilst the total for 'Cars' maybe 10, you could actually end up with the total for buses etc.
If the type_id is an incremental integer then you could stick an ORDER on the type_id column in the query, at least then you could match up the labels to the dataset.
However, personally i'd do this from a slightly different angle - firstly, use PHP to generate a multidimensional array, then encode and output (with the correct headers) JSON data, something like -
Code:
    "Cars": {
        "Ibiza": 10,
        "Escort": 20,
        "Focus": 15
    "Bus": {
        "Yellow": 3,
        "Red": 5
    "Lorry": {
        "Big": 10,
        "Small": 5
Then use JS (or a JS library) to grab the JSON data (via Ajax/XHR), iterate through it and create instances of the charts accordingly (or if ChartJS supports external datasets then try and use the built in functions).
Doing it this way, you not only grab the label names for both types and models but also the totals (obviously totals for types would be a sum of the model totals).
A bit more work but it gives you a little more flexibility if you wanted to add additional types or models etc.
OP
28 Sep 2008
Britain
Code:
    "Cars": {
        "Ibiza": 10,
        "Escort": 20,
        "Focus": 15
    "Bus": {
        "Yellow": 3,
        "Red": 5
    "Lorry": {
        "Big": 10,
        "Small": 5
Hi visibleman, thanks this is pretty much what I want, as, as you've highlighted, the dataset could change and my labels, being hardcoded wouldn't. I suspect I can reach a JSON file externally from jsChart, although I haven't investigated that.
I'm not expecting you to watch this, but this chap pretty much covers what I want where he pulls two results arrays (one for the labels and one for the values, but I suspect they are in the same table).
(from about 8 mins on)
How, with a join, can I get an output like your example?
OP
28 Sep 2008
Britain
Code:
Hi Tom, thanks for this. I don't have `name` in my asset_details field so this errors. the model table has model_id and model_name values though.
OP
28 Sep 2008
Britain
Change the `name` to `model_name` and it should work.
Like this?
Code:
SELECT `model_name`,`model_id`, COUNT(`asset_details`.*)
GROUP BY `model_id`,`model_name`
Gives:
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '*)
FROM `asset_details` INNER JOIN `model_name` ON `asset_details`.model_id = `' at line 1
Any idea? I think, though, I have it working. I have this code:
Code:
<?php
$statement = $pdo->prepare("SELECT t.type_name AS type, md.model_name AS model
FROM asset_details p
JOIN type t ON t.type_id = p.type_id
JOIN model md ON md.model_id = p.model_id");
$statement->execute();
$results = $statement->fetchAll(PDO::FETCH_ASSOC);
$json = json_encode($results);
print $json;
That is giving me:
Code:
[{"type":"Car","model":"Ibiza"},{"type":"Lorry","model":"VT250"},{"type":"Car","model":"Nova"},{"type":"Car","model":"Ibiza"},{"type":"Bus","model":"RM750"}]
Now I just need to find a way to get those into the dataset for chartJS with an effective count (ie, only list Ibiza once in the label, but show a chart result of 2). My next challenge :D
OP
28 Sep 2008
Britain
Apologies I thought your 'model' table was called 'model_name' but yes what you've posted was what I was going for :)
No worries. Any idea how using my query I can get the count, rather than it displaying each value separately? ie:
Code:
[{"type":"Car","model":"Ibiza":"count":"2"},{"type":"Lorry","model":"VT250":"count":"1"},{"type":"Car","model":"Nova":"count":"1"},{"type":"Bus","model":"RM750":"count":"1"}]
Man of Honour
26 Dec 2003
Shropshire
Code:
Code:
SELECT t.type_name AS type, md.model_name AS model, count(p.model_id) AS ModelCount
GROUP BY t.type_name,md.model_name
OP
28 Sep 2008
Britain
Code:
Tom, I could literally drive to your place of work, and kiss you. Very much getting there now. Thank you
