- 30 Aug 2018
This worth a change from my binned 5.1 8700k delidded from OcUK?
The 9900k is a fantastic cpu but like the 8700k, whether or not you will be able to clock it as high as 5.1GHz depends entirely on the quality of the silicon you get. You may end up with a 9900k that only does 4.9GHz or you may get one that does 5.4GHz or higher as well as anything in between.
Will you use the extra cores of the 9900k vs the 8700k? If you just want extra threads have you considered Ryzen? If you want extra threads and speed have you considered Zen 2 expected to release around July?
I went from 8700k to 9900k and I don't have any regrets at all. I use the extra cores and managed to get a good overclocker, AND I wasn't prepared to wait 6-8 months for Zen 2 to release. If I had an 8700k now and wanted more performance for less than the asking price of a 9900k I might be tempted to wait with Zen 2 expected in 2-3 months. Then again what people know about Zen 2 is still largely rumours and conjecture right now.
If you can afford it and want the best then the 9900k is hard to beat. But if you arent going to use the threads and you lose the lottery then you might end up with less performance compared to your 5.1GHz 8700k in anything that values clock speed over threads.
I would say if you don't know whether you need to upgrade then you should hold off for a while. On the other hand if your 8700k dies tomorrow and you need a drop in replacement then the 9900k is a great option if you will use the extra cores over the 8700k.
