Are you asking if you are using the gears correctly? It’s hard to tell from the sped up video.
I’m not being judgemental but if you want to improve your riding to make it safer and faster, have a read of this:
Motorcycle roadcraft: the police rider's handbook https://www.amazon.co.uk/dp/0117081884/ref=cm_sw_r_cp_api_i_WwzQCbBW98WT3
How's your head this morning?![]()
I doubt that your bike’s alternator is putting any charge into the battery with the engine idling.
Faulty alternator then ?
None of the bikes I’ve owned put any charge into the battery with the engine idling. If you’ve fitted a new battery and it’s not charging, you need to get the alternator tested.
I revved the bike and on reading up the reading from my volt meter should have been 14.4v it was 12v
