I guess it gives the illusion of it being an edgeless design which was a selling point a few years back. Personally I see it as a bit of a gimmick now but could live with it depending on how it's done.
Curved tempered glass screen protectors are few and far between. The only ones that are worth buying in my experience and research are those UV cured liquid glue ones like those Dome Glass ones made by Whitestone. Otherwise you have to contend with ugly dot matrix. There will also be issues if the underscreen finger print sensor is ultrasonic (6T is camera based but still has issues with some). Pretty sure the only one certified by Samsung for the S10/10+ is the Whitestone.
Personally I'd just stick with the factory film screen protector. One Plus do glass screen protectors but the 6T one was very fragile and didn't have to deal with curves.
... When I got my One Plus 3 it lasted me a surprising amount of time before I got the "itch" so to speak and upgraded. If you can hold out it really does have its benefits and makes the next purchase so much more rewarding in terms of improvements.
