The Division 2 - March 2019
after each world tier you should have a project to upgrade the bench. You might have already done it, have you been the project person? You might need to do some mats farming as when I did it was lacking in titanium.
I have been doing the projects, I'll take a look through them tonight
@SS-89 nice roll you got on the nemesis.. think mine is around 277k
tried it out in firing range and it seems to hit very hard, might actually have a sniper worth using now
I think mine is around 360k @ 500. Biggest headshot that I would consider "normal" was around 2.4 million vs an elite (1 shots then @ Challenge). I did see a 3.1 million against one of the big armoured mini gun guys, but I think something else from the group was boosting that.
I can see it becoming a meta pretty soon either as a secondary for the headshot damage, or building a really strong sniper build around it. Damage is on par if not a bit more at times than the specialisation sniper which is insane, best to enjoy it while it lasts :D
And if you use the C79 (3.4x) 5% DTE scope it will work with the 25% bonus headshot damage from the Nemesis holstered talent.
That's pretty much the way it's always been since Div 1 unfortunately :(, something gets to popular it usually ends up being nerfed in some way.
When an exotic sniper is capable of hitting harder than the specialised sniper I'm pretty sure somethings going to happen to it. I really hope it doesn't as an exotic it should be strong.
So the trend will be if something gets popular nerf it, oh dear. :(
i wouldnt say this is the case with the nemesis, its clearly better than any other sniper including the specialisation one
and it shouldnt be
saying that i dont think it should be nerfed, rather the spec one should be buffed.. that should be 1 headshot kill / 2 body .. because you need to be more accurate with that thing than the grenade launcher or xbow
also with the charge mechanic it has, it should be the most damaging..
im not a fan of the nemesis really, ive never liked weapons that need to charge up shots.. much prefer to pray and spray with my AR :D
Loving this, I'm early into the game and only at Lvl 14 so still lots to do. Sometimes feel a bit underpowered weaponry wise up against enemies at this point, does that start to change a wee bit at some point as the levels progress?
On an aside - I just swapped out my GTX760 for an MSI Gaming X 1060 6Gb. The 760 was running the game pretty well at medium settings with a decent fps but this thing blows it out of the water! All settings on Ultra at a solid 60fps at 1080p. Loving it. :D
Players cant be blamed,as we always looking what works best for us.
Certain balance team needs to work harder ;)
They can nerf what they want,not gonna affect my build at all :D
