The Radeon VII Owners Thread
27 Jan 2019
try this, take mem to 1200 set core voltage to 1.500mv set power to +6% and let the core boost itself, some times it will boost higher on its own. and your temps should be lower.
1.5v are you sure? Is this a typo? If I set mine to a voltage it will generally work to that voltage no matter the speed, bringing the temps up guaranteed. At that voltage I can’t imagine considering the heat at 1200mv+
28 Nov 2018
London
Yeah boosts around 1900.. if I set 1950mhz 1100mV (1080mV stock) boosts to around 1988. I'll set like this and that's it. Too much headache for now. Thanks for trying to help!
25 Jan 2010
How many people have fitted the alphacool block? I've not attached mine yet and just received an email stating there can be an issue with certain board manufacturers. For those that have it installed which brand do you have?
27 Aug 2005
Kent, England
Just received the same email.
Ladies and Gentlemen,
thank you for your order from us and your interest in our products.
Unfortunately, we have found that various manufacturers use components with different heights. In the attached photo you can determine which component it is.
Before mounting, please ensure that the component does not exceed a height of 1.85 mm. If the component is higher, we ask you not to mount the cooler as it can lead to a defect of your hardware.
If the component is larger than 1.85mm, please contact us.
26 Sep 2010
Stoke-on-Trent
I quoted the whole email so no. On the day mine is out for delivery too. Wish I'd bought EK or Bykski instead.
But surely this problem affects EK and Bykski too?
If board partners are using non-reference components on their reference boards, everybody who's made a block based on the reference design is going to fall foul of this.
20 Oct 2007
It's worrying but it's probably worth noting a few things:
1. EK and Bykski blocks likely suffer the same problem. The companies measure the height of the PCB components to ensure a snug block fit. They probably only have one sample to go from.
2. Realistically, if you've fitted the block and it's working there's a 99% chance that you have nothing to worry about. A taller chip would cause damage during the installation process and not gradually develop over time.
