APM
APM
9 Nov 2011
Wales
My vpn will re-connect,generally in the middle of the night, and I'll get an error message that says 'unexpected re-direct'.
Any ideas why?
20 Mar 2015
Big NOOB to VPNs … and a Virgin Fibre user.
What's the deal with not being able to access VPN sites with Virgin?
As an example I get this when trying to Access the NordVPN website
Cannot securely connect to this page
This might be because the site uses outdated or unsafe TLS security settings. If this keeps happening, try contacting the website’s owner."
Same on my mobile devices until I switch WIFI off and just go 4G, then I can access the NordVPN website. Same with other VPN sites I try to navigate to.
Thanks
APM
APM
9 Nov 2011
Wales
Sounds like Virgin is blocking access to VPN websites,unless you have the router or your security set up to block outdated certificates etc?
26 Feb 2011
Miles South of OCUK
Thanks
Virgin cable connects alright
NordVPN: online security for everyone
APM
APM
9 Nov 2011
Wales
Thanks
Do you use MalWareBytes,could be that blacklisting those sites?
20 Mar 2015
Thanks for the replies.
I've tried the following and still no joy:
1. Disabled Virgin Router Firewall
2. Disabled Windows Defender Firewalls
3. Cleared SSL State / Cache
Browsers I'm using are Google Chrome, Edge and Edge Chromium (Canary)
Any suggestions for my next port of call?
Cheers
20 Mar 2015
Thanks for the suggestion SupraWez, but nada.
Nothing with VPN switched on and bog standard pages such as Amazon load instantly when I switch it off.
APM
APM
9 Nov 2011
Wales
Anyone know why I would get an 'unexpected re-direct' message and have my vpn connect to a different server than the one I chose?
27 Jun 2006
Not here
I am finding, more and more, that NordVPN's IP addresses are being blocked by Amazon and the like. You may find that if you get a VPN from the likes of Nord etc, that you have to get a static IP option as well.
I was discussing this with my friend. a lot of companies are promoting the use of NordVPN such as BBC program Click. Yet its NordVPN you would use to bypass iPlayers restrictions, which people are saying its hit and miss now.
14 Dec 2017
Aberdeenshire
What do you think would be best to get? Nord or express? Looking for unlimited vpn hopefully works with Netflix. I work away 3/3 and the servers are in Norway for our internet so need something to get me back into the uk
maj
maj
19 Jul 2010
Durham
Not tried Express but I find Nord's geo-locking for UK content to be hit and miss. Their IPs seems to be commonly known and are blocked by likes of Netflix whenever I try. I'd see if you can get a week's trial with them both and seem which performs better.
