I think they need to put a lot more into the stuff that they produce. In my house the name alphacool goes hand in hand with ghetto cooling, some of my little mining cards have some properly ghetto cooling solutions on them which almost always involve zip ties. Some of these solutions I rate as better thought out than some of the alphacool stuff.
Overall I'm very happy with the Alphacool stuff. Rads, fittings, bayres are all fine. The tubing has gone cloudy after only 5 months use though but I'm replacing that during this rebuild with Mayhems ultraclear. The RGB strip was always going to be removed in my build so I'm not that bothered by it.
GPU block is fitted, card is in the case, need to flush the new 240 rad and then put both rads in the case, finalise the tubing, fill and leak test.
I'll leave that for tomorrow.
I think we'll see V64 performance at best. That said like with Polaris we'll see Navi age well so by the time we get to Navi's 590 it'll be past the V64 and edging closer to the VII
