The WD Gold hadn't been around for many months
Here's another test as I have disabled the Optane drive
My old 640gb WD black hdd (optane disabled)
My old 640gb WD black hdd (optane enabled)
in the real world thought what dose all this mean? for you that use's the drive as a main drive you may get a performace boot on the data that on the modul, but what about the data thats not.
the cost of the modul and 4tb drive you could have got 4tb of SSD.... (just saying)
I wont have to upgrade or buy another optane again though, just change the hard drive when/if I need more space.
It takes 12-13secs (no optane) and 4-5secs(optane enabled) loading up a stage in DiRT Rally and like I have said before every file or game I access from the hdd once, gets stored onto the optane and will run from the optane in the future.
but when you chance the HDD it will cost money. and i assume by this time SSD will be even cheaper.. so just add more, in the same why you will add HDD's
but it will also add files like filmes and so on as you use them, so over time files are removed from the optane drive to make room, watch a 8gb HD moves ever few days and the drive is will full of filems that are ready for fast use
in your case it may work well, but other using to to boost drives that are used ones a twice a week there is no benifit. drives that are used to dump/store rearly used files will not do load to the optane drive
Phil2008, pleased you got the WD Gold installed, what do you think of the noise of the drive. I think my 2TB Gold drives are very quite indeed. In my same case I have some Samsung Eco Green 1.5TB 5400RPM drives and the WD Gold are quieter then these.
To be honest I cant hear the gold drive at all, all I can hear are my case fans even when I put them on low
BTW I have the same board as you, however run a i7 8700 (non K). My VRM temps can get hot and that's with a small CPU under-volt, how do you find VRM temps?
Also I see your using a X-Fi XtreamMusic, I'm running an original Asus ST in the legacy PCI slot. I got this motherboard as it saved me changing sound cards.
When I stress the cpu with burntest the vrm temps get into the low 70's but I haven't had anything crashing because of this, so Im not too wrorried about the temps.... I have been using the good old x-fi card for donkies years and its been great and still is great, but I fear that this board might be the last board that I'll be able to use it with.
Hey just noticed the new drive is clicking every 5 secs or so accept when it spins down.. people says this is normal but I dont think it is? It appears to run fine though with no errors?
Im disabling the optane on this drive and will do some testing on it tomorrow.
I have returned the gold drive back for a refund as the constant clicking was more annoying then anything else, so Im looking out for another bargin WD drive as all the new 4tb drives on major sites are over the £160 mark.
n air from the cpu onto the VRMs and the rear case fan sucking the warm air out. Nothing fancy at all, Im even using the same cpu cooller from my i5 2500k cpu. Thats the main reason I haven't overclocked the cpu any higher then 4.9 as the high 60's is hot enough for the cpu.. When I stress my cpu I havent seen the VRMs go over 73c
