- 27 Apr 2007
Sure but in very limited quantities so hardly equivalent as a comparison against new retail parts.Again, I don’t think you understood what I actually said, ES and QS chips are available *before* retail parts, with a little knowledge, you can in some cases buy retail stepping chips for significantly less than retail price.
Also your choice of compatible motherboards is often much more limited with these chips
Most I've seen don't use the same stepping as the retail parts and the ones that do tend to be priced higher.
