Provided that the tyres are the same size, load rating & speed rating, yes.Stupid question incoming! I've got an F11 BMW that no longer has run flat tyres on, will the recommended tyre pressures still be the same even though the tyres are no long runflat?
They are the same size but the load and speed rating are different.Provided that the tyres are the same size, load rating & speed rating, yes.
They should be 245/45 R18 96Y, they are 245/45 R18 100Y XL MichelinPilot Sport 4.What should they be and what are they?
Soft sidewalls, which is why on track they are gash but well suited to a big cruiser.I can't praise my Assy 3s enough. The ride is excellent and it's lovely and smooth on the motorway. I also rarely ever see the DSC light, I saw it all the time with the factory PZero fitted.
Hard to believe these are runflats.
What's a good mid range set for size 18 wheels? They would be 225/40/18
What size? Black circles have a few deals on Mich/Goodyear/hankook/bridgestones.Tyres need replacing on my 2013 Fiesta. Not sure which brand to go with. Decent price on the Avon ZZ5s, but from what I've seen, durability isn't great. What would you recommend? Budget £70 a corner fitted.
I've decided to keep my stock 16" and been looking to replace the Lassa Driveways that came on them and have been on the lookout for the last week or so.
PS4 if they're the same price, proven time and time again.What's the verdict on the new Eagle F1 AS5?
I have AS3 all round with the fronts on the limit, would either go for these or swap onto Michelin PS4 for the same price.
225/40/18.
I've just ordered a set of Michellin Primacy 4s for my Leon Mk3. 205/55/16 at £65 per corner fitted with £40 off code 4MICH40 at blackcircles.com205/40/R17
It was between the P4s, Turanza T005s, Goodyear EfficientGrip, Uniroyal RS3 for me.
Saved me a fair bit of money on an already expensive service, with a faulty aircon system and bonnet latch sensor.
