16 May 2019 at 16:01 #1 RobTi RobTi Associate Joined 23 Jan 2005 Posts 1,454 ok first thing do I want noobs or just Raspbian, then do I just connect up and hit run or install?
17 May 2019 at 12:43 #2 alexakasloth alexakasloth Soldato Joined 13 Aug 2004 Posts 8,407 Location England With noobs you copy and paste the files across to the microSD card then slot into the Pi and run it. https://projects.raspberrypi.org/en/projects/noobs-install
17 May 2019 at 14:08 #3 RobTi RobTi Associate OP Joined 23 Jan 2005 Posts 1,454 Thanks read up but can’t decide if I need noobs or Raspbian
17 May 2019 at 16:42 #4 alexakasloth alexakasloth Soldato Joined 13 Aug 2004 Posts 8,407 Location England Noobs is a method of installation, a tool to install raspbian/ open elec etc.
18 May 2019 at 08:58 #5 RobTi RobTi Associate OP Joined 23 Jan 2005 Posts 1,454 okay went for rasbian for the moment, ssh and vnc set up with my dektop, off to find more info now. Thanks
26 Jul 2019 at 19:44 #6 TangoEchoAlpha TangoEchoAlpha Associate Joined 13 Jun 2016 Posts 1,542 Location UK RobTi said: okay went for rasbian for the moment, ssh and vnc set up with my dektop, off to find more info now. Thanks Click to expand... Definitely worth installing PiHole
