- 19 Oct 2008
Modern LCD monitors I think are much safer, easier on the eyes than the old CRT types.
A few additional things not already mentioned. Screen breaks of course but also focus on something in the distance often if you can. A tree outside a window, lamppost in the distance, a pretty lady(or bloke) in the office opposite
. If facing into an open plan office, something at the other end of the office.
Brightness should not be much brighter than around the monitor. So if first thing in the morning you turn the monitor on and it seems bright in relation to the surroundings then it probably is. Obviously it needs to be bright enough to see it but if you're in a dark office then the brightness needs to be lower. Bright office, then higher.
Make sure you read all the leaflets the company give you and do the H&S questionnaire. Don't be afraid to speak to someone if you feel ANY discomfort.
